Sorry for long post. Been a while since built PC and feel like a lot has changed.
So bit of context. Upgrading from 2080ti & 3900x, which usually I would not upgrade so quickly but my daughter is due a PC upgrade so she is getting that (she plays 1440p) and time for me to get an upgrade... Use is gaming 4k and photo editing / normal work. I run 3 displays of this. A 4k, ultrawide and 1440p.
I am going full aircooled (moving from a full loop watercooled) build. So only concern I have really is with noise as I am used to just setting my 011 to static fan speed and not having any ramp up or down etc. Not sure if this is possible on air.
Couple issues I have had with current build; I have never really overclocked my current build mainly because even trying to get XMP profile working has been an issue, as I would get random crashes every couple of days with it on. Additionally most of my drives are still Sata except for the boot drive which was a 250gb nvme.
Things I am a little confused about on the below build is...
Case - Does a window / solid side panel impact noise of the case. I select the Fractual as it seems to do well in reviews for noise although I am not sure if the reviews I have seen make sense as they seem to use stock configuration fans rather than filling the case like you would do with some of the bigger cases. Would something like the HAF 500 / 700 be better for cooling / noise or anything else?
GPU - Anything wrong with OC card? it seems the same price as the windforce, which I beleive is normally a cheaper version? Anything I am missing here? Is there a better brand model?
Memory - is 32gb enough? with this being dual channel can I add another 2 sticks later down the road if games require more (believe 32gb is becoming more common now).
CPU - Any reason to get K vs KF? one is cheaper but can't see any differnce except onboard graphics
PSU - Does this come with the connectors for 4090? Is there another PSU I should look at?
Motherboard/HDD -- I am really confused the M.2 impact on lanes. Will 3 M.2 impact the GPU as it seems to be shared? I don't really see a reason to go with nvme 5.0 drives so assuming ones picked are ok?
Thanks for any help people can give. Again sorry for long post.
1 X Gigabyte GeForce RTX 4090 Gaming OC 24GB GDDR6X PCI-Express Graphics Card - £1,699.99
SKU: GX-1FC-GI
1 X Asus Prime Z790-P WIFI (LGA 1700) DDR5 ATX Motherboard - £269.99
SKU: MB-6JR-AS
1 X Kingston FURY Renegade 32GB (2x16GB) DDR5 PC5-51200C32 6400MHz Dual Channel Kit - £248.99
SKU: MY-29N-KS
1 X Intel Core i9-13900KF (Raptor Lake) Socket LGA1700 Processor - Retail - £599.99
SKU: CP-6B6-IN
1 X Fractal Design Torrent Black Solid Mid Tower Case - £214.99
SKU: CA-09U-FD
1 X Noctua NH-D15 Chromax Pure Black CPU Cooler with Dual 140m Fans - £109.99
SKU: HS-03M-NC
1 X Corsair RM1000e Fully Modular 80PLUS Gold ATX Power Supply - £159.95
SKU: CA-271-CS
2 X WD Black SN770 2TB SSD M.2 2280 NVME PCI-E Gen4 Solid State Drive (WDS200T3X0E) - £159.95
SKU: HD-58G-WD
1 X WD Black SN850X 1TB SSD M.2 2280 NVME PCI-E Gen4 Solid State Drive (WDS100T2X0E) - £109.99
SKU: HD-590-WD
Grand Total: £3,748.48
YOUR ORDER
close1 X Gigabyte GeForce RTX 4090 Gaming OC 24GB GDDR6X PCI-Express Graphics Card - £1,699.99
SKU: GX-1FC-GI
SKU: MB-6JR-AS
SKU: MY-29N-KS
SKU: CP-6B6-IN
SKU: CA-09U-FD
SKU: HS-03M-NC
SKU: CA-271-CS
SKU: HD-58G-WD
SKU: HD-590-WD
