Hi Guys, my mate just purchased a base unit from you today and i am also interested in doing the same.
My rig is over 4 years old and doesn't cut it anymore for some of the games i play. It will be used for gaming, at the moment i am playing Diablo 3 mainly with the odd mmo and plan to play guild wards when it comes out and who knows what else. A point i would like to make is i don't play fps, not anything serious anyway.
I have a nice 23" monitor, mouse etc i could maybe tempted with a new keyboard as mine is very old and does need replacing, but i wouldn't want an expensive one, just something that does the job. I wouldn't really put the keyboard price into my main budget, but if theres anything that would come recommended i would have a look at it as an addition.
My budget is around 700-800 pound. And the max would really be 800 unless it was really worth it.
I know a bit about components, but i want something that comes pre-built. I would say the knowledge i have is the basics, ive replaced a hard drive and graphics card, i have been in my case many times etc, i know what everything is, what it does, i know a fair bit about the levels of graphics cards and processors as i have done a fair bit of research and kept an eye on the market, read some reviews, but..
At the end of the day i don't really know what i should purchase to get the most out of my budget.
I have seen that ssd drives are now the in thing and are superb with booting up windows and games fast, however with my budget it might not be something thats worth it? i could maybe add that in at a later date.
I would also consider using a gpu which i could crossfire at a later date maybe in a couple of years when i need to keep up with the times. I assume its an easy enough process to install another card?
I would also mention i have a copy of windows already. would this restrict me to anything purchasing a rig without an os installed?
Thank you for your time reading my wall of text. If i have missed anything i will be keeping a keen eye on this thread.
