build advice
18 Jun 2011
ok so i am intrested in building myself a computer however i have no idea where to begin, the only thing i will be using it for is general browsing and playing a gamed called world of warcraft. would it be possible to build a tower cabable of this for £150-170? could anyone point me in the right direaction? thanks
for that money theres no way your getting a new system that will play WoW at any sort of decent graphics.
can you tell me exactly what you have right now so i can say if theres anything that can be salvaged from your current computer
if you are unsure as to what you have, then you can download a program called CPUz that will tell you the name of all the major parts of your system. it wont be able to tell me the name of your case, power supply or DVD drive though.
The possible option is to look at the second hand market.
As already mentioned we might be able salvage certain items from your current pc, assuming you have one! :eek:
