- 11 Mar 2004
After a midrange PC build and have read many spec builds but it's more confusing to me than ever. If anyone remembers the old bartons, then the opterons ....my pc knowledge has deteriorated since then. The last time I wanted an upgrade, all the rage was on the Q6600 and through the confusion, I just bought a Dell having the Q6600 (regret, and therefore want to self-build this time).
I'm not after bleeding edge, a good midrange system around 450 for the base only with no operating system required.
Not after a complete spec, the advice I'm seeking at the moment is:
Q: What is 'in' chip/mobo/gfx card best value combo to look at now?
System quietness is a major factor as is the ability to play some of the recent games e.g. crysis/mw2 etc.
PS. My monitor resolution is 1920x1200.
Many thanks in advance.
