Cheers for the replies, the bundles you've mentioned on OC are worth looking into. The 1660ti is the gigabyte variant by the way. As for the aorus boards, I was probably gonna upgrade later this year to that as well as grab a 2070.
Yep, 250Gb pretty much disappears as soon as it sniffs the case.Same as @Plec but bigger SSD.. always add cheap HDD afterwards. Bit of a pain cloning to bigger drive and that 240GB will fill up fast .. 10 GB lost after format and 40GB to windows..
Yeah, i saw the variant before you edited your post. As mentioned the windforce comes with twin copper heatpipes so worth the extra if you're after cool running.Cheers for the replies, the bundles you've mentioned on OC are worth looking into. The 1660ti is the gigabyte variant by the way. As for the aorus boards, I was probably gonna upgrade later this year to that as well as grab a 2070.
