build advice
9 Sep 2025
uk
Hi need some advice, rethinking which cpu to buy for my first build, i intended to buy amd 9800x3d but wondering if there is a better option, need the cpu for general windows use and multitasking but also want excellent gaming results, if i had the money i would go for the 9950x3d but its currently about £200 more than the 9800x3d so too much. i like the gaming benchmarks on the 9800x3d but wonder if getting more cores would help me in windows and if i could save some money somewhere without losing much gaming performance.
current expected specs :
9800x3d?
msi b850 edge ti
64gb ram
1/2 tb m.2 drive
850w/1000w psu
9070 xt
hi thanks for the replies, 70% of the time i will be in windows with multiple browsers open and multiple tabs within each browsers and be moving files in the background and watching videos etc, when i do play games i want to be able to play them at their best and not worry about low fps. just wondered if the 9800x3d was my best option, been sorting out my pc build now for a number of months and the 9800x3d was always my 1st choice but maybe there is a better option?.
That's nothing the 9800X3D can't handle, you still have 8 fast cores.
The Zen 6 X3D is believed to have 12 cores per CCD, if so, that would be even better, but the 9800X3D should be more than enough for that kind of usage.
The 265K is a good price for a mixed usage/productivity CPU, but you'd lose a chunk of gaming performance, so not worth it unless your alternative usage is very heavy.
so my choice is between the 9700x and the 9800x3d, just dont know how much difference there is as i have looked at benchmarks but not many benchmarks have 9070 xt at 1440p comparing the 2 models.
9700x is a great all rounder but the 9800x3d is a better gaming chip but what most videos don't show is the 1%and the .1% lows which is the fps in most demanding parts of the game this is also where the x3d shines.
Price difference is about £130 if you think thats worth spending elsewhere in your build or saving then so be it but you always pay a premium for the best.
what kind of workload are you using?
9800x3d and 9950x3d are practically the same for gaming, and even for regular workloads 8 cores is probably enough. If you are doing some heavy CPU stuff then go for the 16 cores. If its specific apps then check online to see the performance difference with CPU
This can give you an idea, but it is highly variable on the game/settings.
If you play the kind of games that like the X3D's cache, the 7800X3D would be a better choice than the 9700X.
i intend this pc to last a number of years so will one perform for more years than the other?
I prefer to simplify this into 2 options:
1. Get the 9800X3D, the most powerful CPU right now and just hope it keeps up with everything for a good while (it will).
2. Get an entry level CPU, like a 7600/9600 (or less) and upgrade to the next X3D one AMD bring out.
100% as above, unless you're doing serious rendering or database work with it (and if so, you'd likely already know that that's what's restricting you), the 9800x3D will do everything just as well as the 9950x3D... except showing you graphs in task manager.
I'll probably try to hold out for the 10950x3D... but I really like graphs ;)
(but as Tetras suggested, cheaper chip now and upgrade to what will presumably be called the 10800x3D would be a solid option too)
I also think the 9800X3D makes the most sense for you from what you have said. It makes the most sense for most people who are likely to be on these forums really.
