- 6 Jan 2012
Hi all,
Looking at building a Vesa mountable HTPC that is capable of a little gaming at 720p. The reason for this resolution is that it will be outputting to a pico-projector over miracast, fortunately this lower resolution also benefits me for cheaper and cooler running hardware.
I had been contemplating an NUC as they seem to very tidy little systems and the Skylake iGPUs seems to of made a lot of progress, but they drivers don't seem to be particularly stable and they're are a bit pricey to boot for what you get.
The following build is looking the most likely route unless news of the Boston Ridge APUs comes before I pull the trigger and they offer desktop models.
Antec ISK 110 VESA- Small and cheap, little worried by the cooling and 90w power supply though
Noctua NH-L9a Low Profile Quiet CPU Cooler- Seems the most suitable for a case of that size
16GB (2x8GB) Corsair DDR3 Vengeance Pro Series - Not to clued up on memory but I've heard bandwidth is pretty important to APUs, don't think kaveri officially supports 2400mhz, but I've heard of people getting benefits from it, stick with this or is there a safer bet with some 2133mhz varieties?
AMD A10 7800- I know there's some slightly more powerful offerings, but the option to switch down to 45w twp seems handy in such a small enclosure with a small power supply.
MSI A88XI AC V2- Pretty much picked at random, if there are better FM2+ m-itx boards let me know, main things are having wifi built in, but if there are some speed or heat savings available let me know.
480GB Crucial BX200- Software drive, last time I built a system SSDs were still a little sketchy with Samsung being a safe bet, have things stabilised now and is this stable drive or would I be better off getting my hands in my pockets for a more reliable drive.
2TB Seagate ST2000LM007 Mobile HDD- Media drive, seem to be some larger capacity ones on the verge of coming out but the cost savings seem worth it.
Comes to just over £500
Aside from the performance of components I'm also wondering if this Hardware supports AMD wireless display with a miracast compatible projector?
Also I'm planning on mounting this underneath a coffee table so its out the way and can just be plugged in and projector placed on top off table when in use. I can see this possibly causing heat issues as the case would normally be in a vertical position rather than horizontal and the motherboard will be a the top so hot air could be trapped against it. I'm hoping the fan of the cooler will be able to push enough air out the sides to prevent this happening. Anyone with more experience have any ideas on how well this will work?
Thanks for any help
Thanks for any help
