Hi guys
Just looking for a quick check over this build for a mate - any incompatibilities/problems or cheaper/same price better options. I'm at the budget limit so I can't go more expensive (other than a couple of quid), but I don't mind going for one cheaper component to make another more expensive.
Usage is mainly gaming, but general quick performance too. He's not into insane framerates or perfect graphics, nor video encoding etc. Rome 2: Total War is the game to bear in mind - I'd like it to run as well on Rome 2 as possible.
I'd rather keep quad core if possible, but if it would give a significantly better gaming experience then I'm open to dropping to a faster dual core and spending the difference on the graphics card. The CPU needs to be able to keep up for a few years though - he'd be happier replacing the graphics card than the CPU+Motherboard.
Any suggestions?
Any suggestions?
Thing is the 460 in that benchmark is at 675mhz, my 460 is OC'd to 850-900Mhz so it well and truly stomps over the 7770. We see 6850/460s go for ~£50 2nd hand on the MM
