Hi all I have created this build and was wondering what people think to it. I was originally wanting to go Micro ATX or Mini ITX but parts are limited on the website. Just wondering if anyone could do changes to it without losing the aesthetics I have gone for and bring the price down a little? Also the reason I have chosen the specific M/B is down to Bluetooth capability for when I would use a Xbox controller. I will be wanting to OC the CPU so if anyone can link me to maybe an air one that is suitable to the job I'm more than happy to swap out the AIO. Wasn't sure if I could go with a lower PSU also?
Also with this build if I wanted to could I drop one of the new Ryzen CPU's into it later down the line when they come out? Will the motherboard support that?
My basket at Overclockers UK:
Thanks
- 1 x AMD Ryzen 5 Six Core 2600 3.90GHz (Socket AM4) Processor - Retail= £179.99
- 1 x Gigabyte X470 Aorus Gaming 5 Wifi AMD X470 (Socket AM4) DDR4 ATX Motherboard= £174.95
- 1 x MSI GeForce RTX 2070 Armor 8192MB PCI-Express Graphics Card= £488.99
- 1 x Corsair Vengeance RGB Pro 16GB (2x8GB) DDR4 PC4-24000C15 3000MHz Dual Channel Kit= £158.99
- 1 x Corsair TX650M 650W 80 Plus Gold Semi Modular Power Supply (CP-9020132-UK)= £98.99
- 1 x Crucial MX500 250GB SATA 2.5-inch, SATA 6.0Gb/s 7mm Solid State Drive= £49.99
- 1 x Seagate 2TB BarraCuda 7200RPM 256MB Cache Internal Hard Drive (ST2000DM008)= £53.99
- 1 x Antec DA601 Dark Avenger Midi Tower Case - Black Window= £82.99
- 1 x Corsair Hydro Series H115i Platinum RGB Performance Liquid Cooler - 280mm (CW-9060038-WW)= £139.99
- 1 x AOC G2590FX 25" 1920x1080 TN 144Hz FreeSync/G-Sync LCD Gaming Monitor - HDMI, DP= £199.99
Total: £1,646.98 (includes shipping: £18.12)
Thanks
The Gigabyte Z390 UD is much better for less. You can't overclock on H370 anyway.
