Build check pls
22 Feb 2004
Middlesex, UK
Ok, going to order this in a few days and wanted a few opinions.
Good or bad.
Also, does anyone know if the DS4's OCUK stock are the rev.2 boards or the old rev.1.
Considering either the DS4 or IP35 but cant decide, someone try and sway me either way.
Have about £1000 to spend so also looking for a decent size screen, probbly a 22". But I know nothing about screens, they show pretty pictures and thats about as much as I know.
Current system spec is in my sig and as you can see, its a POS now.
The only thing I might be tempted to do is change the RAM for some Ballistix PC2-6400 and also some some decent thermal paste. You could also consider changing the CPU for an OEM but if the extra warranty on the retail is important then leave as is.
So you think the Balistix is a better option than the GeIL.
Had a bloody nightmare with my old Balistix, stuff died on me atleast 3 times. Although the RMA was damn fast.
Your probbly right about that Q6600 too, but what the hell its only an extra £2.
Of course AS5 on the Q6600 is a given :D
