Build check plz
22 Feb 2006
Anychance someone could have a look over this for me and see if ive made any errors. Cheers
Thermaltake VA3000SWA Tsunami Dream SuperMidi Aluminium Tower - Silver (CA-011-TT)
Hiper HPU-4B580 Type R 580W Modular ATX2.2 PSU - Blue (CA-006-HP)
AMD Athlon 64 X2 Dual Core 4200+ (Socket 939) - Retail (ADA4200BVBOX) (CP-126-AM)
Asus A8N32-SLi Deluxe nForce4 SLi X16 (Socket 939) PCI-Express Motherboard (MB-118-AS)
Western Digital Caviar SE16 250GB 2500KS SATA-II 16MB Cache - OEM (HD-046-WD)
Gainward BLISS GeForce 6800 GS "Goes Like Hell" 512MB GDDR3 TV-Out/Dual DVI (PCI-Express) - Retail (GX-027-GW)
OCZ 2GB (2 x 1GB) PC3200 Dual Channel Platinum Series EL-DDR CAS2 (OCZ4002048ELDCPE-K) (MY-057-OC)
NEC ND4551 16x16 DVD±RW Dual Layer LabelFlash ReWriter (Silver) - OEM (CD-028-NE)
Mitsumi FA 404M 7in1 USB 2.0 Floppy & Media Drive - Silver (HD-000-MI)
Anyone see any problems ?, also will the cpu heatsink and fan supplied be okay or is it worth me getting a new one straight away ?
Welcom to the forum :)
Yeah all looks ok. The stock cpu heatsink and fan will be fine unless you plan to overclock it loads? but even a small overclock on stock fan/heatsinks will be ok.
The hiper PSU seems to get a lot of stick on this forum, so i would suggest changing it to the Tagen if you want modular, or the seasonic.
Yeah i havent overclocked my 4200 yet but i think they are good for 2.3/2.4 on stock fan/heatsink.
Some people on here will tell you to get the 3800, but as your not overclocking just yet stick with the 4200, like me :D
Looks fine but if you can spare the extra cash you would really be much, much better of with this graphics card ... especially considering the rest of the spec (if you game)... Connect3D ATI Radeon X1800 XT 256MB GDDR3 AVIVO TV-Out/Dual DVI (PCI-Express) - Retail (GX-044-CO) ... Much better card than the 6800GS. The X1800XT is the biggest bargain in top-end cards at the moment.
