build check :)
18 Sep 2005
Lian-Li PC V1000 PLUS Aluminium Midi-Tower - Black
£109.99 (£129.24)
Hiper HPU-4M580 Type R 580W ATX2.2 PSU - Black
£47.99 (£56.39)
Asus P5N-E SLi nForce 650 (Socket 775) PCI-Express DDR2 Motherboard £69.99 (£82.24)
Intel Core 2 DUO E6400 "LGA775 Allendale" 2.13GHz (1066FSB) - Retail £124.99 (£146.86)
Thermaltake Blue Orb II Socket 939/754/775) CPU Cooler (CL-P0257) £15.95 (£18.74)
BFG GeForce 8800 GTS OC2 320MB GDDR3 HDTV/Dual DVI (PCI-Express) - Retail £199.99 (£234.99)
G.Skill 2GB DDR2 HZ PC2-6400 (2x1GB) CAS4 Dual Channel Kit (F2-6400PHU2-2GBHZ)
£129.99 (£152.74)
Western Digital Caviar RE 160GB 1600YS SATA-II 16MB Cache - OEM £35.99 (£42.29)
Sony AW-G170AB2 18x DVD±RW x12 Ram Dual Layer DVD-Writer - (Black) OEM
£14.99(£17.61)
Sony Floppy Drive - Black
£4.99 (£5.86)
Microsoft Windows Vista Home Premium 32-Bit Edition DVD - OEM - 1Pk (66I-00715)
£63.99 (£75.19)
Creative X-Fi Xtreme Gamer 7.1 Soundcard - OEM
£39.99 (£46.99)
that totals to £1024 - a friend recommended parts and I chose suitable ones matching what he said that were available from this site. Im thinking of overclocking the processor but not substantially - main thing im worried about is cooling, will the two case fans be enough? There are of course a lot of cases available but im pretty darn picky about looks - and i dont want it to be plastic / plasticy looking (NZXT Zero looks plasticy / is plasticy, i dont know which).
Other cases I like the look of are the wavemaster - ive got one already but with only an 80mm exhaust it might be needing another from what ive read, the other case thats interesting is the lian-li PC-A10, so if anyone has views on any of the meantioned cases that would be great :P
Ram and PSU - i dont know if they are the best I kind of just picked ones in a hurry.
GPU - Ive heard some great things about the 8800GTS 320mb - good price / performance.
All suggestions welcome, thanks.
EDIT: I forgot to add a sound card, but I do want a dedicated card in the final build rather than on-board.
EDIT 2: Added soundcard to spec.
Edit 3: With this setup, do you think the 420w supply i have lying around at home will be good enough, or am i gonna need a 500+?
ah, i thought i had selected the intel e6300, missclicked i guess,
i was bound to be off on ram, psu and HDD (i forgot to mention this one was also one i selected fast :p) As i didnt know anything at all about which were the best companies etc for these components i thought i would just select one that looked to be a reasonable price and see what people had to say.
Thanks for your help, will take a look at all the mentioned items, if anyone else has any suggestions, feel free to chime in :)
