Build Check
14 Mar 2007
This is going to be my first build i would appreciate if you could point out any problem would arise from this set up or anything i have missed out.
I dont need a monitor, mouse speakers or keyboard.
Intel Core 2 Duo E6420, Socket 775, 2.13 GHz, 1066MHz FSB, Allendale Core, 4MB Cache, Retail
Asus P5N32-E SLI NF680i SLI, S 775, PCI-E (x16), DDR2 533/667/800, SATA II, SATA RAID, ATX
2GB (2x1GB) CorsairTwinX XMS2, DDR2 PC2-6400 (800), 240 Pins, Non-ECC Unbuffered, CAS 5-5-5-12
320MB XFX 8800GTS, PCI-E (x16), Mem 1600MHz, GPU 500MHz, 96 Streams, 2x Dual Link/DVI HDTV
Western Digital Caviar SE16 320GB 3200KS SATA-II 16MB Cache - OEM
Pioneer DVR-112DBK 18x18 DVD±RW Dual Layer ReWriter - (Black) OEM
Microsoft Windows Vista Home Premium 32Bit 1Pk OEM (DVD)
OCZ GameXStream 700w Silent SLI Ready ATX2 Power Supply
Thermaltake VA8003BWS Armour Super Tower - Black
Thermaltake Big Typhoon 4 in 1 Heatpipe (Socket 939/754/775/478) CPU Cooler (CL-P0114)
I will eventuly be getting a second 320MB XFX 8800GTS and a water based cooling system
£1000, if you want to make changes the only thing i would not change is the case and the cpu, other than that feel free
