- 6 Jun 2011
- EU...
i'm building a pc soon and i've gone through several iterations of builds, here's the latest one (think i'm done with the tweaking now). what do you guys think? anything you would recommend i change? i'm pretty much overbudget (£800) already so i definitely don't wanna spend any more, but it'd be nice if you could recommend cheaper componenets which would do me just as well. it's for internet/music usage as well as gaming at 1920x1080. i also want to leave myself upgrade room in each component (eg extra wattage psu) so i save money in the long run. i definitely don't think i'll go down the sli route with another 560 ti but for only £4 over the P67A-C45 (which is the same mobo but missing the second pciexpress slot) i may as well go for the G45 just in case i change my mind.
Intel Core i5-2500K 3.30GHz (Sandybridge) Socket LGA1155 Processor - Retail £169.99
MSI P67A-G45 Intel P67 (Socket 1155) DDR3 Motherboard ** B3 REVISION ** £101.99
Kingston HyperX Genesis Grey 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit £44.99
MSI GeForce GTX 560Ti Twin FrozR II 1024MB GDDR5 PCI-Express Graphics Card £173.99
Crucial RealSSD M4 128GB 2.5" SATA 6Gb/s Solid State Hard Drive £173.99
Cooler Master Silent Pro Modular 600W Power Supply £79.99
Zalman Z7 Plus Midi Tower Case - Black £43.91
LG GH22NS70 22x DVD±RW SATA ReWriter (Black) - OEM £16.99
Norton Internet Security 2011 - OEM (DVD 1 User) £17.99
Total: £838.82 including shipping
ps. I'm getting windows 7 free through my uni, that's why it's not included in basket
. out of interest, in what way is the GD53 better than the G45? i compared the specs of the two on MSIs website and the only difference i could find was 2 pci express x16 slots, and a lack of firewire and internal USB3. is there a difference in component quality or performance? or overclocking potential? (i don't plan to OC anytime soon but will probably stick an aftermarket cooler on and do it in a year or two).
