Build compatability
19 May 2025
uk
Is all this compatible please​
  • Corsair NAUTILUS 360 RS ARGB 74.37 CFM Liquid CPU Cooler
  • Gigabyte X870E AORUS ELITE WIFI7 ATX AM5 Motherboard
  • (2 x) Corsair Vengeance RGB 32 GB (2 x 16 GB) DDR5-6000 CL36 Memory
  • Crucial T500 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive
  • Gigabyte GAMING OC GeForce RTX 5090 32 GB Video Card
  • Corsair 3500X ARGB ATX Mid Tower Case
  • Corsair HX1000i (2023) 1000 W 80+ Platinum Certified Fully Modular ATX Power Supply
  • AMD Ryzen 9 9950X3D 4.3 GHz 16-Core Processor
i'm expecting this to have usb 4 as well?
Will be using corsair hx1200i 2025 version, not the one in list so hope thats fits
Have you decided to build this machine yourself, or is this a suggestion for someone else looking to do so?
It should work, but going for 4x16gb on the RAM might prove problematic, you're better off with 2x32gb.
Yes gonna build myself and the RAM ive selected wrong, should be 2 x 32gb.
Not sure if the case supports usb4
Purley gaming build the 9800x3d is all you need
I would probably up the PSU to at least 1200w as the the 5090 can have massive power spikes , Google it .
If if want usb 4 which the motherboard has do I just get a
4 PORT USB 3.0 INTERNAL PCI-E CARD?​
