Build complete
16 Aug 2004
Thanks for the advice
Finally built
All fine but can’t work out how to get the RGB fans to light up. I have them plugged into fan headers..that makes them run. Prob post this on the case section.
Please shout out if anything looks wrong.
Description: Phanteks Eclipse P400 Air Midi Tower DRGB Case White with Vertical GPU bracket and riser cable Commodity:N/A
*Build* INTEL CORE I5-12600KF 3.70GHz Socket LGA1700 - TRAY
Arctic Liquid Freezer II High Performance CPU Water Cooler - 240mm
Asus TUF Gaming Z690-Plus D4 - Intel Z690 LGA 1700 DDR4 ATX Motherboard
Corsair Vengeance LPX 32GB (2x16GB) DDR4 PC4-25600C18 3600MHz
Description: Seasonic Focus GX-750 750W 80+ Gold Modular Power Supply
Description: Phanteks Eclipse P400 Air Midi Tower DRGB Case - White
Description: Sapphire Radeon RX 6700 XT Pulse Gaming 12GB GDDR6
Description: WD Black SN770 2TB SSD M.2 2280 NVME PCI-E Gen4 Solid State Drive
Will add photo when I work out how
Are the fan rgb cable plugged into anything.... a hub/motherboard headers... if using motherboard headers make sure they are compatible with your rgb fans before plugging in.
As for photo... you need to upload to an online host and link it here.
