So I've just attempted to build my first PC from scratch. It's harder than I thought considering I've tinkered about with them for a while, but not in detail. Does anyone live in Willesden, London?
I will pay if needs be.
The mobo is an ASUS H81M-Plus
There are lots of cables from the power supply (super flower bronze) that don't seem to go anywhere:
- 4 red ones (two of which say PCI express and are 6 pin) that I can't seem to connect to the GPU (MSI Radeon R7 250), though maybe I don't have to.
- One blue connector (8 pin) that says CPU 1 on it, but that doesn't seem to go anywhere either.
To add to this, I have a DVD drive from my old PC which is IDE only! The Mboard has no IDE capacity (it's Micro ATX) so I think I may have to try installing windows using a bootable USB.
I will try and get some pictures, though it's a faff.
Any help?
Any help?
