Build Critique Please
13 Jan 2004
Considering the following build:
Any revisions you think I should consider?
You don't need the sata cables. Sata 3 cables are exactly the same as sata 2 cables, and your motherboard will come with loads of them. Unless it's the 100cm long that appeals, but I'm not sure they'll be needed even for that case.
Assumed the III had a difference seeing as they are branded that way, if not I'll just use other ones.
Not really...I mean 6Gbps = 750MB/sec. SSD = 280MB/sec max. Worth it ? I think not.
EDIT: If using 2 SATA 3 SSDs in something like RAID 0 maybe, but you're not. So for now pointless.
