Shopping Basket;
CPU –
http://www.overclockers.co.uk/showproduct.php?prodid=CP-278-AM&groupid=701&catid=6&subcat=1946
- Quad Core Technology
- 3.10GHz Clock Speed
- AM3 Socket
- 2MB L2 Cache
- 64-Bit Technology
- HyperTransport 3.0 Technology
- AMD Virtualization (AMD-V) Technology
- 3 Year Warranty
- Heatsink & Fan Included
CPU Cooler –
http://www.overclockers.co.uk/showproduct.php?prodid=HS-010-TI
- 4 x 8mm heatpipes with Heat Pipe Direct Contact feature: for rapider heat conductivity
- 12cm ultra-silent fan with nine kukri-shaped blades
- Newly revamped fan is perfect for comprehensive cooling capacity and extremely noiseless operation at 15 dBA only
- PWM intelligent fan controller: provides an excellent balance between high and low speed
- High density fin design: large surface for heat dissipation while overclocking
- All-in-one socket support: compatible with Intel LGA 775/LGA1155/LGA1156/LGA1366 and AMD K8/AM2/AM2+/AM3 systems
DVD-RW –
http://www.overclockers.co.uk/showproduct.php?prodid=CD-099-SA
Write Speed
- DVD-R: 22x
- DVD-R: 22x
- DVD-R DL: 12x
- DVD+R DL: 16x
- DVD+RW: 8x
- DVD-RW: 6x
- DVD-RAM: 12x
- CD-R:48x
- CD-RW: 4x
Read Speed
- DVD-R: 16x
- DVD+R: 16x
- DVD-R DL: 12x
- DVD+R DL: 12x
- DVD-RW: 12x
- DVD+RW: 12x
- DVD-RAM: 12x
- CD-R: 40x
- CD-RW: 40x
Ethernet Cable –
http://www.overclockers.co.uk/showproduct.php?prodid=CB-002-BE&groupid=1929&catid=1069&subcat=
GPU –
http://www.overclockers.co.uk/showproduct.php?prodid=GX-103-MS&groupid=701&catid=56&subcat=411
- Core Clock: 725MHz
- Twin Frozr II Thermal Design
- Voltage adjustment
- Ideal for overclocking
- Memory: 1024MB GDDR5
- Memory Clock: 4000MHz (Effective)
- Memory Bandwidth: 256
- Processing Cores: 1440
- Bus Type: PCI-Express 2.1
- Display Connectors: 1 Dual-Link DVI-I, 1 HDMI & 1 DisplayPort
- HDCP Capable
- DirectX 11 Support
- OpenGL 3.2 Support
- ATI CrossFireX Ready
- ATI Eyefinity Technology
- ATI Avivo HD
- ATI Stream Technology
- 2yr Warranty
HDD –
http://www.overclockers.co.uk/showproduct.php?prodid=HD-206-SE
Capacity: 500GB
- Cache: 16MB
- Interface: SATA-II
- Spin Speed: 7200RPM
- Seek Time: 8.5ms
- Warranty: 3 Years
Keyboard –
http://www.overclockers.co.uk/showproduct.php?prodid=KB-140-MS&groupid=702&catid=23&subcat=1258
- Advanced anti-ghosting capability
- Mode switching between desktop and gaming mode
- Automatic profile switching
- 18 Programmable macro keys
- In-Game macro record buttons
- Backlight mode with 4 Illumination Levels
- Media keys
- USB powered
- 3 Year Warranty
Motherboard –
http://www.overclockers.co.uk/showproduct.php?prodid=MB-134-MS&groupid=701&catid=1903&subcat=1782
- Support for 64bit AMD Phenom II and Athlon II CPU
- HyperTransport 3.0 supporting speed up to 5200MT/s
- AMD 870 and SB850 Chipset
- 4x unbuffered DIMM of DDR3 800/1066/1333/1600*/1800*/2000* (OC) DRAM, 16GB Max
- 1x PCI Express 2.0 slot with x16 operation
- 1x PCI EXpress 2.0 slots with x4 operation
- 1x PCI EXpress x1 slot
- 3x PCI slot, support 3.3V/ 5V PCI bus Interface
- 1x IDE port
- 6x SATA-III (6Gbps) support RAID 0, 1, 5, 10 mode
- Flexible 8-channel HD audio with jack sensing
- Gigabit LAN
PSU –
http://overclockers.co.uk/showproduct.php?prodid=CA-035-CS
- Supports the latest ATX12V v2.3 standard and is backward compatible with ATX12V 2.2 and ATX12V 2.01 systems
- Rated up to 600W of continuous power output at 30°C
- Ultra-quiet 120mm fan delivers excellent airflow at an exceptionally low noise level by varying fan speed in response to temperature
- Up to 80% energy efficiency means less heat generation and lower energy bills
- 0.99 Active Power Factor Correction provides clean and reliable power
- Universal AC input from 90~264V — No more hassle of flipping that tiny red switch to select the voltage input!
- Dedicated single +12V rail offers maximum compatibility with the latest components
- Over-voltage and over-power protection, under-voltage protection, and short circuit protection provide maximum safety to your critical system components
- Extra long fully-sleeved cables support full tower chassis
- Two year warranty and lifetime access to Corsair's legendary technical support and customer service
- Complies with ErP Lot 6 European Union standard for low standby power consumption
- Dimensions: 5.9"(W) x 3.4"(H) X 5.5"(L); 150mm(W) x 86mm(H) x 140mm(L)
- MTBF: 100,000 Hours
RAM –
http://www.overclockers.co.uk/showproduct.php?prodid=MY-222-OC
- 1600MHz DDR3
- CL 8-8-8-24 (CAS-TRCD-TRP-TRAS) (1.55v-1.65v)
- CL 9-9-9-24 (CAS-TRCD-TRP-TRAS) (1.45v-1.55v)
- Available 4GB Dual Channel Kits
- Unbuffered
- Special Ops XTC Heatspreader
- Lifetime Warranty
- 1.55-1.65 Volts
- 240-Pin DIMM
CPU –
- AM3 Socket
- 2MB L2 Cache
- 64-Bit Technology
- 3 Year Warranty
CPU Cooler –
DVD-RW –
Write Speed
- DVD-R: 22x
- DVD-R: 22x
- DVD-R DL: 12x
- DVD+R DL: 16x
- DVD+RW: 8x
- DVD-RW: 6x
- DVD-RAM: 12x
- CD-R:48x
- CD-RW: 4x
Read Speed
- DVD-R: 16x
- DVD+R: 16x
- DVD-R DL: 12x
- DVD+R DL: 12x
- DVD-RW: 12x
- DVD+RW: 12x
- DVD-RAM: 12x
- CD-R: 40x
- CD-RW: 40x
Ethernet Cable –
GPU –
- HDCP Capable
- ATI Avivo HD
- 2yr Warranty
HDD –
Capacity: 500GB
- Cache: 16MB
- Seek Time: 8.5ms
- Warranty: 3 Years
Keyboard –
- Media keys
- USB powered
- 3 Year Warranty
Motherboard –
- 1x IDE port
- Gigabit LAN
PSU –
RAM –
- 1600MHz DDR3
- Unbuffered
- Lifetime Warranty
- 1.55-1.65 Volts
- 240-Pin DIMM
