Build for £400-£450
9 Jan 2011
Nottingham
I don't need a graphics card or a hard drive.
I'm thinking:
Intel Core i5-2500K 3.30GHz (Sandybridge) Socket LGA1155 Processor - OEM
Asus P8Z68-V Intel Z68 (Socket 1155) DDR3 Motherboard
Zalman Z9 Plus Tower Case with Fan Controller - Black
Kingston HyperX Genesis Grey 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (KHX1600C9D3X2K2/8GX)
LG GH22NS70 24x DVD±RW SATA ReWriter (Black) - OEM
Not sure on the PSU.
Would like to be able to overclock in the future when I buy an after market cooler.
If you could bring the price down to £400, with good overclocking ability, it would be good.
Edit: Forget that, there was no mention of SLi or Crossfire before I posted :(
What GPU do you currently have and are you thinking of going SLi or Crossfire with another one of these ???
YOUR BASKET
1 x Intel Core i5-2500K 3.30GHz (Sandybridge) Socket LGA1155 Processor - OEM £161.99
1 x Gigabyte Z68AP-D3 Intel Z68 (Socket 1155) DDR3 Motherboard £79.98
1 x Cooler Master Silent Pro Modular 500W '80 Plus Bronze' Power Supply £49.99
1 x Kingston HyperX Genesis Grey 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (KHX1600C9D3X2K2/8GX) £29.99
1 x BitFenix Merc Alpha Gaming Case - Black £29.99
1 x Gelid Tranquillo CPU Cooler (Socket 754/939/940/AM2/AM2+/AM3/LGA775/LGA1155/LGA1156/LGA1366) £25.99
1 x Sony Optiarc AD-7280S 24x DVD±RW SATA ReWriter (Black) - OEM £17.99
Total : £395.92 (includes shipping : FREE).
Yeah neither of these are SLI/CF ready. I wouldn't recommend that case for SLI/CF, 1 card setups = great. Also go for the Retail i5. You want to keep your warranty, and its great for re-sale.
Can you link me to a case you like?
Assuming you want to go sli/cf in the future, what Gpu do you have at the moment. Will you sli/cf this or will you be upgrading. This info will help the guys in their specs.
You could alternatively stick with the spec and upgrade your psu later, when your finances allow.
Ineed to type faster.
With the items listed in first post and the psu you linked to, cost about £460+, with delivery. Can you stretch your budget. I assume you have an OS, as you have not mentioned.
no one seems to have mentioned it but in your first post you chose an oem cpu but not speced a 3rd party cooler, oem cpu don't include the intel stock cooler for that you want the retail version which is £180(so I would suggest the oem + gelid tranquilo unless you want the 3yrs warranty of the retail).
That link you posted for the Psu, i can`t see it. The only XFX 850 is non modular.
modular http://www.overclockers.co.uk/showproduct.php?prodid=CA-000-XF&groupid=701&catid=123&subcat=1497
non modular http://www.overclockers.co.uk/showproduct.php?prodid=CA-005-XF&groupid=701&catid=123&subcat=1497
overbudget but I would say
YOUR BASKET
1 x Gigabyte Z68XP-UD3 Intel Z68 (Socket 1155) DDR3 Motherboard £99.98
1 x XFX Pro 850W Core Edition '80 Plus Bronze' Power Supply £79.98
1 x Zalman Z9 Plus Tower Case with Fan Controller - Black £49.99
Total : £480.91 (includes shipping : £12.50).
the ram price ends monday morning so you need to order tonight.
