Hi all and thanks for looking
I am currently using a I5 6400 with a 1060 3gb gpu. I am a complete novice at pc's, but from what I can see, it would be easier to start afresh rather than trying to upgrade present system on a H110M-S2h Motherboard.
I have a budget up to £1,000.
Could you please put together a decent build for me ? I was thinking along the lines of a Ryzen 5 3600 with a RTX 2060 or something like that. 1TB SSD. I#ll consider any other options though. Me and my son mainly use it for the normal teenager FPS games, football manager, Sims 4. But I would like to get into the newer AAA games.
I have just bought a AOC 27" IPS (144 Hz) monitor if that helps the advice.
Appreciate any help.
Thanks
Noel
Thanks
Noel
