I was building a little workhorse pc for my parents.
I put this together:
My basket at Overclockers UK:
Total: £328.47
(includes shipping: £0.00)
But, I forgot that they want to run two monitors. The main board has two visual out puts a dvi and a vga and I'm happy to run the two monitors out of these, but is it possible? If not is there an inexpensive desktop pc (my mum does word mostly and little surfing/iplayer) graphics card I can be advised on?
Also my dvi cable will not fit in the port. The wider flat plug is ok, but my cable has 4 pins, two above and two below the flat wide pin, but the port does not have this, any ideas on what I need to adapt my cable?
Thanks for any help/advice.
- 1 x Intel Core i3-6100 3.70GHz (Skylake) Socket LGA1151 Processor - Retail= £99.95
- 1 x Asus H110M-K Intel H110 (Socket 1151) DDR4 Micro ATX Motherboard= £46.99
- 1 x WD Black 1TB 7200rpm SATA 6Gb/s 64MB Cache HDD - OEM (WD1003FZEX)= £62.99
- 1 x Zalman T1 Plus Mini-Tower USB 3.0 - Black= £19.99
- 1 x Super Flower Golden Green HX 350W "80 Plus Gold" Power Supply - Black= £45.95
- 1 x Samsung SH-224FB/BEBE 24x DVD±RW SATA ReWriter (Black) - OEM M disc compatible= £12.95
- 1 x Kingston Fury Black 8GB (2x4GB) DDR4 PC4-21300C15 2666MHz Dual Channel Kit - Black (HX426C15FBK2/8)= £32.99
- 1 x Akasa AK-FN057 Apache Super Silent 120mm Fan - 4 Pin PWM= £6.66
Total: £328.47
