Hi all,
Currently an Antec Skeleton owner, running a Q6600 on a full ATX with H50 cooler.
Wanting to downsize now, main reason being is that I seem to be lugging my PC round more and more to various LAN's, friends houses etc. Also the novelty of the Skeleton has wore off now. The dust is quite frankly doing my head in. So wanting to go SFF but re-using most of my existing components as money is a little tight![Smile :) :)](/styles/default/xenforo/vbSmilies/Normal/smile.gif)
Ill be using the Lian Li PC-Q07B case.
I need help in picking a motherboard though. It needs to be Q6600 compatible, support dual channel RAM, and have a PCI-E x16 slot, for as cheap as possible. Been looking at the Zotac G41 at the moment....is this the safe bet?
Anyone know the max length of graphics card Ill be able to fit in this case? Ill be using a 2.5' drive in the bottom so clearence for that shouldnt be an issue.
Ill most proably have to get rid of the H50 as well.....what cooler would be the best? Seen a Alpenföhn Panorama 'Low Profile' CPU Cooler' being used on another build on here.
Any advice would be apppreciated!
