Will the Hydro 105 fit that case?
The removal of the lower plate inside the case by means of a few screws enables a 240mm rad to be fitted internally in this position. The total space for the rad and fans being determined now only by the distance to the cable management holes and grommets, so pretty much anything you care to lob in there, even the 86mm deep brick like Alphacool NexXxos Monsta shouldn't be a problem.
Will the 105 cooler fit that case?
Heard bad things about the Asus Sniper mobo
Thanks
