Build help/advice
18 Mar 2023
uk
Hi all I have chucked this basket together, if anyone could advise on better parts for similar cost I would be grateful. Also can I ask what fans and cables I'll be needing too 2k budget thanks.
My basket at OcUK:
Total: £1,704.84 (includes delivery: £0.00)​
Overpaying for Asus stuff which are normally overpriced and also have worse features for the same money in comparison to other manufacturers
You haven't specced a case...is that intentional?
Assuming this is just a gaming system, then I would make the following changes for a 2K budget:
AMD Ryzen 7 7700 Eight Core 5.30GHz (Socket AM5) Processor - Retail - £338.99
Gigabyte B650M DS3H (Socket AM5) DDR5 Micro ATX Motherboard - £199.99
Kingston FURY Beast EXPO 32GB (2x16GB) DDR5 PC5-48000C36 6000MHz Dual Channel Kit (KF560C36BBEK2-32) - £139.99
(unchanged)
Asus RX Radeon 6700 XT Dual 12GB GDDR6 PCI-Express Graphics Card - £389.99
AMD Radeon™ Get The Game Bundle - The Last of Us™ Part I - £0.00
WD Black SN850X 1TB SSD M.2 2280 NVME PCI-E Gen4 Solid State Drive (WDS100T2X0E) - £89.99 (OS/boot drive)
WD Black SN850X 2TB SSD M.2 2280 NVME PCI-E Gen4 Solid State Drive (WDS200T2X0E) - £149.99 (game drive)
Lian-Li GALAHAD AIO 240mm High Performance RGB CPU Water Cooler - White - £119.99
Lian Li Lancool 205M Mesh Micro-ATX PC Case White - £74.99
MSI MPG A1000G PCIE5 UK PSU 1000W 80 Plus Gold Power Supply - £159.95
(unchanged)
Microsoft Windows 11 Home 64-Bit DVD - OEM (KW9-00632) - £127.99
(unchanged)
Asus External Slimline DVD Re-Writer, USB, 8x, Black, Cyberlink Power2Go 7 - White (SDRW-08D2S-U LIT - £29.99
(unchanged)
LG 27" 27GQ50F-B 1920x1080 VA 165Hz 1ms FreeSync DyAC Widescreen Gaming Monitor - £179.99
Grand Total: £2,001.83 (delivery charge, £0.00)
You shouldn't need any additional fans or cables with the build above.
I went with a white case because you have a white DVD re-writer, but you can swap the case and AIO for black versions (and save £5).
the way i see it is that storage can always be added on later on with no detriment...it's literally an "add-on" rather than a replacement unless changing the os drive
(and even then the old os drive can then be repurposed to become secondary storage...so no loss)
if you want a better cpu/gpu this will have the hassle of needing to buy a new one, and then selling the current one at a loss
might as well get the best cpu/gpu combo within budget, then storage can be sorted out at a later point in time when the need arises
Yeah, makes sense. I think I was content with the 6700 XT just because the OP is buying a 1080p monitor, so I loaded up on the rest of the build (CPU, storage, PSU), but going 1440p with a 7900 XT is going to be so much nicer to game with.
I'll be honest I thought I had one in my basket but any advise is really appreciated.
(unchanged)
(unchanged)
(unchanged)
(unchanged)
Awesome thanks I'll be honest I'm excited to put this together
you know that you can cram in a better system with a 7900XT for a 2k budget?
the 7900XT is an order of magnitude faster than a 6700XT?
Exaggeration aside, the 7900XT is basically double the performance of a 6700XT
It would be a shame if you spent £2k just to settle for a GPU that only rightfully belongs in a £900 rig in 2023
And worse of all, setting for a 1080p monitor
Both the above is criminal for a £2k outlay
