Build help needed
27 Dec 2020
Hi putting together my pc build. My spec is as follows case=nzxt h510, motherboard= Msi b450 gaming plus max, cpu= ryzen 7 2700x, ram= Corsair vengeance 16gb and I have an xfx rx 5600 xt thicc 3 and it won’t fit. I have checked compatibility which says it fits but It won’t seem to go in. Any advice?
Hi @Finley Kay Welcome to the forum. Please remove the reference to the website you mentioned as they are classed as a competitor and no references are allowed on here as its OC UK's website. Paid for and ran by them :)
nzxy h510
graphics card is limited to 381 mm in length.
https://www.xfxforce.com/gpus/xfx-amd-radeon-tm-rx-5600-xt-6gb-gddr6-thicc-iii-ultra
Card Dimension (cm) 32.6 x 14.8 x 4.4
It should easily fit int he case. Is that what your asking??
Pictures would help.
Hi
Appreciate your message....edited :)
The graphics card dosnt seem to want to click into the graphics card slot, tried it on the lower one as well. Ill Post some pics so as you can see. Thanks
