Build Help Please
7 Nov 2013
Corby UK
hello all, im a bit of a mess here.
anyway looking for help and solutions to a couple of issues im having.
1st off i have just purchased the thermaltake view 32 case from here and cant seem to get the fans working. not sure how i go about it as there dosent seem to be anywere on my board to plug in.
2nd my power supply cable is not long enough to reach my mobo connection. unsure also what i need.
here are my specs and i will also add a couple of images to assist your help and advice.
please help
HTML:
https://imgur.com/a/jBSFGfk
Windows 8.1 64-bit
32.0GB Dual-Channel DDR3
Acer Predator G3-605 (LGA1150)
2047MB NVIDIA GeForce GTX 1660 SUPER
regards
Mick
That's an odd layout on the motherboard.
Guessing its proprietary stuff, in which case, unlikely there is anything you can do other than getting a new motherboard and PSU.
i had an idea that would be the issue,
can you give me any suggestions on a new board that would work with the the new case i have so the fans would work.
and even a psu.
appreciate the assistance
Mick
Socket 1150 is out if date, you can probably pick up a board 2nd hand.
Motherboards: 6.7” x 6.7” (Mini ITX), 9.6” x 9.6” (Micro ATX), 12” x 9.6” (ATX) will all fit.
PSU - I'm not up to speed on whats best these days, I have a modular 650W Super Flower.
Yes, that will fit in the case, but your processor wont fit in the board.
Are you planning on replacing that too? (Would also need to replace RAM if so.)
will that board have the correct connections for the case rgb fans as currently i cant run them.
and to answer your question seeing as i have purchased the new case, with a good card im going to replace the psu , gpu and also the ram to ddr4.
thanx for the help appreciate your time .
