OK, so I'm new here and a little premature in my questions but, I will be building a new rig in the summer, probably July time. The exact timing is dependent upon a couple of things but primarily, I want to see what direction, timescale and pricing the new Robson tech will take.
Anyways, will be looking at building a quad core with most likely a R600 (again, this depends on whether the NV 8900 or 8950 are out or likely to be soon at that point).
My question is pretty basic actually regardless of the above ramblings. Whn building your PC is it normal to throw everything together before the big switch on or is it recommended to put it together in stages? i.e. add in PCI cards one at a time to make it easier to identify any potential problems?
I mean, your going to have to put the basics on to start with, CPU, ram, hd, GPU on but... hey, you know what I mean anyway
Excuse me going on, work gets boring sometimes.
Vorm.
Vorm.
