Hi I have purchased the following list on advice from your great forum. I have some problems I wonder if you can help
Corsair XMS2 4GB (2x2GB) DDR2 PC2-8500C5 TwinX Dual Channel (TWIN2X4096-8500C5C) £60.42 1 £60.42
Asus M4A77D AMD 770 (Socket AM3/AM2+) PCI-Express DDR2 Motherboard £51.05 1 £51.05
AMD Athlon II X2 Dual Core 240 2.80GHz (Socket AM3) - Retail £39.99 1 £39.99
Corsair CX 400W ATX Power Supply (CMPSU-400CXUK) £34.88 1 £34.88
XFX ATI Radeon HD 4650 1024MB DDR2 TV-Out (PCI-Express) - Retail £31.48 1 £31.48
ThermoLab Baram CPU Cooler (Socket AM2/AM3/LGA775/LGA1366) £25.52 1 £25.52
Coolermaster Elite 334 Midi Case - Black £23.82 1 £23.82
I have done a clean install on windows XP I have reused my old hard drive which is ok and the DVD drive the problem is when I install the graphics card driver and re start. I see the first windows screen then the screen goes blank its not crashing. I can only think that the card is faulty? Then I have to go into safe mode and uninstall the driver to get it going again.
It also after installing all the drivers keeps telling me to install faster usbs or something like that. Any help would be great
Thanks Ben
