Build Help!!!
Here are the specs
Computer Case : Cooler Master CM-690 II Advanced dominator
CPU : Intel Core i5 2500k (4 x 3.30GHz)
CPU Heatsink : Cool master Hyper 212 plus
Memory : OCZ Platinum 4GB (2X2GB) 1600MHz
Graphics Card : 2 x ATI Radeon HD 6970
Motherboard : 1 x Asus P8P67 Pro Intel P67 DDR3 *Revision B3*
Sound Card : N/A
Networking : 1 x Motherboard Integrated Ethernet Lan (Broadband Ready)
USB Ports : 1 x 6 x USB 2.0 Ports & 2 x USB 3.0 Ports
Firewire Ports : 1 x 1 Port Firewire IEEE 1394 (Built In)
Power Supply : 1 x XFX PRO 750 Core edition power supply
Hard Drive #1 : Seagate Barracuda 7200.12 1TB sata-II 32MB
Optical Drive #1 : 1 x Samsung (SH-S223C/BEBE) 22 x DVD
Monitor : BenQ G925HDA 18.5" Widescreen LCD monitor - Black
Sound System : Edifier R1600T Studio Plus 2.0 Monitor
Cheers - All power connectors in including the 8 pin for cpu power, double check the memory are in the correct slots.
On the graphics card theres an 8 pin port and a 6 pin port, I only have the 6 pin port connected up as I cant see any 8 pin from the PSU. The mother has its two power leads onto it, the big plug ( 24 pin?) and two 4 pin plugs in its 8 pin port, one with a red dot on the plug casing. Am i missing anything?
There's your problem right there.
