BUILD HELP
22 Aug 2012
hello i am looking to build a PC but i do not know the best products to get. i know what case i am wanting to build it in and a few things which i would require in the build such as:
8gb of memory
bitfenix shinobi white
i5 processor
but however i need some help with the other things like motherboard, CPU, PSU, GPU, Storage.
i have a budget of £500 for the computer without the screen keyboard and mouse.
i would like to use this computer for gaming, editing and general use really.
i would like the mobo to be 1155 socket. so could you all help me please and suggest parts or a full list of parts i could get for my build for £500
it would really help me out.
cheer gardenshed
Yeh it is possible, if you want a bad computer or are happy with second hand items, and without a decent GPU.
i managed to find this lot for 515 without the case but i have spoken to parents and they said they would buy the case.
Your basket
Intel Core i5-3450 3.10GHz (Ivybridge) Socket LGA1155 Processor (77W) - Retail - £154.99
Sapphire HD 7770 OC EDITION 1024MB GDDR5 PCI-Express Graphics Card - £119.99
Gigabyte Z77-D3H Intel Z77 (Socket 1155) DDR3 Motherboard - £81.98
BitFenix Shinobi "Core" USB3.0 Gaming Windowed Case - Black - £54.98
OCZ ZS Series 550W '80 Plus Bronze' Power Supply - £49.99
Corsair Vengeance Blue Low Profile 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit - £44.99
Toshiba (7K1000.D) 500GB SATA 6GB/s 32MB Cache - OEM - £44.99
Sony DDU1681S-0B 18x DVD-ROM (Black) - OEM - £13.99
Total : £565.91
what do you all think?
If you dropped the aftermarket cooler, it would save a bit of money, but not allow you to overclock as high.
The reason i picked that one was because it is an overclock able version. It can reach 4.5Ghz quite easily. This will increase your CPU performance by a fair bit and in turn last you a lot longer. I have the previous gen chip and Overclocked it makes a great difference, for no further outlay.
You don't but it will increase performance and usually keeps the CPU going for a few more years than a non overclocked one.
With a simple air cooler a 4.4Ghz overclock can be made. This is about a 20% performance increase.
*sigh*
Read rules, your not allowed to link to competitors. So remove the link before your banned.
What was the name of the GPU?
