Hi all,
trying to put my PC together and have hit a confusing matter. trying to install the PSU into my Phanteck Luxe case. If I install it with the Superflower writing facing up and from the rear the Eco button is the correct way up the fan actually is facing into the case and once the PSU cover is back on then the air will be trapped. If I turn the PSU upside down the fan faces down and will flow air under the case through the vent.
Any suggestions?
Any suggestions?
