Hi guys,
Hopefully this is the right place to post this but if not, please move it to the correct place!
I've started building my PC today after my 5600x arrived yesterday. So far, I've got the CPU and cooler on, mobo mounted, RAM is in and PSU is bolted in too. I'm just plugging in cables from case to mobo and i've hit a bit of a wall.
For clarity, Ive got a ROG Strix B550-F Mobo and a Phanteks P400A case.
MOBO Manual: https://dlcdnets.asus.com/pub/ASUS/...ING/E16609_ROG_STRIX_B550-F_GAMING_UM_WEB.pdf
Case Manual: http://www.phanteks.com/assets/manuals/PH-EC400ATG.pdf
Firstly, am I right in saying the HDD LED +- should go in the bottom right hand side horizontally, and the Power SW should go the same way?
Secondly, MB D/RGB 3PIN - i presume this is the RGB lights that need connecting to the MOBO but i'm unsure where to connect these - in the manual, it says in section 11 I can connect RGB LED strips but the diagrams are all 4-pinned & this isn't that connection..
Thirdly, the front panel HD Audio I'm pretty sure i've placed correctly but would appreciate someone having a look
Fourthly, i've connected the USB 3.0 front panel cable to the USB 3.2 Gen1 header - is this still OK?
Any help appreciated!
