- 11 Aug 2009
- Glasgow/Miami
Tried my first watercool setup back in December, since then i have wished i had done a bit more and been more patient. Now that i am home on leave for a while i decided to give the rig a bit of an overhaul. I am planning the following,
Change I/O brackets on 7970's to single slots
Install Back Plates to 7970's
Install crystal link bridge between 7970's
Install brighter LED's to raystorm GPU & CPU Blocks
Install a Aquaero 5 XT controller and inline temp/flow sensors
Change out all barb fittings to compression
Install a drain point to loop
Apply MX-4 to GPU's and CPU's (used xspc's own stuff first time around)
Install quick disconnects to external rad to allow moving and cleaning of rig easier.
Install waterblock for VRM's/MOSFET's
Replace 3 140 fans in 800D case
Here is a photo of all the Kit, going to make a start today
