Build Log : Project Skint (MM build)
project clean out more like :P
hehe no point tidying it up going to be ripping it all out in a couple of weeks.
Ive got to say im using the setup as my main machine now and im getting more and more impressed, considering i could have 2 of these up and running for under what i paid for my full rig.
Before i make a final decision im going to move my I7 into the same case and do some side by side testing, considering i will stack them on top of each-other its still a only a little bit bigger than my T07.
Would be be great to get some info on how your i7 works in that case sayso. Trying to decide on budget AMD quad build or i7/i5 with a Asus Maximus III Gene/Asus Rampage II Gene to put in the Lian Li v351 whilst i wait for the case to come back in stock.
Both the 1156 and 1366 sockets have a much better micro atx range than AM3, but produce more heat afaik and are considerably more expensive... hmm indeed. :(
Cool, got a 5850 /24'' monitor/fan controller coming tomorow, in preperation for that v351 case. Swaying towards an i5/Asus Maximus III Gene with the i5 watercooled atm, only 2 left in stock too:eek:
Only thing im not sure about is the SB/NB heat from the Asus mircroATX boards, some reaching 80c and causeing shutdown.
