[Build log] Spare PC
14 Oct 2003
South Derbyshire
OK I decided to build a computer to use while my main rig is going to be dismantled and rebuilt with new parts and a new case and so on.
That project is going to take some time and cost allot of money and a project log will be created for that.
However I bought some parts from a friend that consisted of an OCUK overclocked bundle
Argon Intel Core i3 2.93GHz @ 4.00GHz Overclocked Bundle
Which can be found here http://www.overclockers.co.uk/productlist.php?groupid=43&catid=339&subid=1803
I also bought an Asus ATI Radeon HD 5870 1024MB GDDR5 to go with it.
Missing a motherboard, case, harddrive & dvd drive I took a visit to ocuk & bought...
The build got under-way and around 30 mins later this was produced.
Cpu, Ram, heatsink installed onto the motherboard.
Motherboard installed
C300 drive installed
As you can see, the OCZ psu 12+ cable is short, I will need an exstention cable for that.
Benchmarks etc to follow soon.
Cpu shot has been through 30 mins of prime so far, more testing is need but shows there is room left in the ocuk bundle.
Few benchmarks of the C300 drive.
Very nice and tidy - how come the core speed is showing 4.2GHz? I thought it was 4?
There is plenty of room left in the 4ghz ocuk bundle, I bumped it up to 4.2ghz,
Last night I had a play at 4.4ghz.
The system feels VERY snappy, but that's down to the C300 drive, SSD makes all the difference.
Noo it will scar your eyes if you see what he has created!
Nath cover your eyes.
The rig is a few years old now.
Core i7 965 @ 4.2ghz, Gigabyte X58 Exterme, 6GB OCZ blade at 2000mhz 18,7,7,7, 1T
3x GTX 280 in TRI SLI 756core/1225 mem, 4 300GB veloci Raptors in RAID-0 over 500MB sec read, samsung F3 1TB backup,
2x 18watt DCC pumps, 2xThermoChill 120.2, TFC 120.1, XSPC 120.1.
Coolermaster 1250/1500watt psu.
3dmark vantage score of 38k
Original thread here
http://forums.overclockers.co.uk/showthread.php?t=17965602&highlight=username_locky
Locky said:
"These Phenom Tri Cores, Snappy in windows!"
there is a 4.2ghz i3 bundle as well as the 4ghz one. good to see you with an rjk special in your system Locky!
the dinosaur. looking forward to your new build. i bet this i3 system plays MW2 just as well as you
:D Although I changed a few settings. But the ocuk/rjk profile is safe :)
It is getting on a bit, The new build will be much better.
Check the MM soon for an influx of dinosaur parts!
I feel one of these will look much better my that Mozart currently sits :D
No more mick take like this :D
Well at least the "breadbin" gets some proper usage, unlike some of the monster builds on here. :P
Just did a vantage run on the spare pc, should be ok for now
Card was clocked at 900/1250 cpu at 4.2ghz, ram at 1600mhz.
Cpu seems solid now, CPU @ 4.2ghx QPI @ 6.4, RAM at 1600mhz 24,7,8,7
