- 16 Mar 2010
PC Spec:
CPU: Intel Core i5
Mobo: Gigabyte P55M-UD4
RAM: 4GB GSKILL Pi Series cas 6
GPU: 4670 then 5770 crossfire
PSU: 750W Be Quiet Dark Power Pro
Case: P180 Mini
Watercooling spec:
Rad: 120 and 240 black ice stealth gt rad powdercoated white
Waterblock:XSPC V3 Delta
Pump & Res Combo: XSPC 450LPH
Coolant: Thernochill EC6 UV Blue
Compression Fittings: Phobya 1,2 id 3/4 od
4 x nzxt fans (getting delivered Tuesday)
tubing
BOX:
BOX OPENED:
COOLANT & Backplate:
Kit opened:
Kit Accessories:
Res & Pump Combo:
Waterblock:
Rad:
since i decided to go for 1/2 ID 3/4 OD Compression fittings i found out that they dont arrive for 2-3 weeks, got really frustrated so i got a pair of pliers and took it out on the hd partition in my case. the partition had to come out anyway so not too fussed anyway i managed to source some compression fittings.
took the hd partition out
before:
after:
fans and tubing:
Compression fittings:
more pics
its currently very hot in my room so i tried getting 4ghz anyways and i did:
4ghz @ 1.36v
idle: 35c
Load: 65
ignore the 67c and 66c that's when i was drinking hot choclate next to the comp when the case was open
once i get more fans and put the 240 rad in push and pull the temps should go down.
armageddon temps:
idle: 43C
Load: 83C and rising (Fail)
i was also able to get my ram to 6-9-6-24 @ 2000mhz
CPU: Intel Core i5
Case: P180 Mini
Watercooling spec:
tubing
BOX:
BOX OPENED:
Kit opened:
Kit Accessories:
Res & Pump Combo:
Waterblock:
Rad:
before:
after:
fans and tubing:
more pics
4ghz @ 1.36v
idle: 35c
Load: 65
armageddon temps:
idle: 43C
