Afternoon all,
I'm newish to these boards and you're all a lovely bunch of people. From research i have the following build to do in March....
(Usage is Games (For the first time in my life not at low graphic settings), photo editing and Photo manipulation)
Proc: SandyBridge 3.4Ghz, 2600K 1155 Socket
Cooling: Corsair H70 Hydro
PSU: Corsair AX 850 (Should last a while)
Case: Corsair 600T (Or the spec Ed version if OCuk have it then)
SSD: OCZ Vertex 2 120 GB (Although just read a review that these aren't 120 Gb anymore due to new 24nM size, any comments?)
HD: Samsung 1Tb Spinpoint (or other standard 1Tb HD)
OS: Windows 7 Pro. (64 bit)
GPU: Nvidea 580 GTX of some sort....(plan to SLi in future)
That's what's been decided. the RAM and Mobo are confusing me on what I should be looking for, and might change between now and mid-March but any advice on either? Costs are running at £100 ish for Ram, £150 for Mobo.(+/- £30 for each)
RAM: 2x 4Gb of ??? (Running Photoshop)
Mobo: ???
Only final note is to replace H70 Rad stock fans with Apache Viper silentx2 plus the
Akasa AK-CB002 PWM Fan Splitter Cable [AK-CB002]
Comments, ideas, suggestions...
Mobo: ???
