Hi, im new to watercooling and id like to get a custom kit instead of just buying a off the shelf kit. I dont know much about which pumps best etc etc and thats where you lot come in. I dont have a massive amount on money to spend but id say £120 is propably the maximum. It will need to be able to fit into a PC7+ and have a 939 compatable waterblock. Also id like it to have a waterblock for the GPU which is a 7900GTO and also hoepfully a quite pump would be prefered.
Thanks Ryan
Thanks Ryan
