Build me a pc for Lan
14 Nov 2012
So i need to get a pc together to give my good fps in CS;GO for Lan events my current pc is too big too travel with so was wondering if people here can help me.
Does an h100 fit in the Hardon? I'm not sure.
Max CPU cooler height 5.5in/140mm.
EVGA Hadron Air:
Compatible with many aftermarket CPU air coolers.
NOT compatible with aftermarket all in one water coolers.
Maximum cooler height is 5.5in
CPU Coolers Confirmed to Fit Hadron Air:
EVGA ACX mITX CPU Cooler
EVGA Hadron Hydro:
Compatible with all in one water coolers, (single 120mm radiator) Example: Corsair H80/H60
Compatible with many aftermarket DIY water cooling kits. EVGA will sell a certified kit separately.
CPU Coolers Confirmed to Fit Hadron Hydro:
Cosrair H60/H80/H100
Source: http://www.evga.com/support/faq/afmviewfaq.aspx?faqid=59448
Damn, i need the Hadron Hydro.. I knew i read it somewhere but forgto they had two versions. :(
just get a gtx 660
Lian Li PC-TU100B Mini-ITX
and everything else just dirt cheap
its only for lan and cs so dont need to spend nearly 1k on it..
Is it worth just getting a laptop as a power sauce anyone know how much il need to spend to get 1900 - 1080p for csgo
I have a GT640 at work which gives me 60fps at 1080p easy. my rMBP gets 35fps or so with Ultra and Full AA settings, with AA down a bit I can get 60fps. So basically anything with a 730m/iris 5200 or higher should get u 60fps.
