Hi! So I need a new PC... and I lack the PC construction skills necessary to build my own, so I wanted to either use the configurator or go for one of the premade systems.
Now I want the PC to be capable of handling games like Crysis at high setting at 1080p, and my budget.. well ideally between £700 and £800, but can go up to £850 if necessary (without monitor or accessories).
Now I have a lot of questions, so please be patient with me xD
and hopefully someone will be able to help me out here, as my knowledge of computer hardware is pretty basic
Firstly, processor: is AMD good at this price range? Or does the equivalent Intel chip still out perform it? The intel are more expensive and seem to have generally lower clock speeds, but I read that lower intel clockspeed still outperforms high AMD clockspeed processors generally.
I also see a lot of people listing Haswell in builds, but I thought that Ivy bridge were generally better gaming as they were better for overlocking and ran cooler?
Second, obviously is the graphics card. I was thinking the HIS HD 7870. Is this decent for my needs? Is it worth spending the extra money for a 7950? Or any other graphics card you would recommend?
One of my main concerns is getting a graphics card and CPU of equivalent power, so that I'm not wasting money on one overpowered component which will be held back by the other.
The rest, I'm not entirely sure which power supply, fans and motherboard I would need, so I picked them somewhat randomly xd or left default. Also I would ideally want a small SSD with an HDD for fast booting.
So I guess the only thing left is OS - I've heard bad things about windows 8, but I've seen a few people recommending it on these forums.. I thought it was a bad interface designed for touch? Which would you recommend?
So here is a £850 spec I made with the configurator:
Your basket
Product Name Line Total
HIS HD 7870 IceQ X 2048MB GDDR5 PCI-Express Graphics Card (H787QN2G2M) £199.99
AMD Piledriver FX-4 Quad Core 4350 4.20GHz (Socket AM3+) Processor - Retail
£95.99
Gigabyte 970A-UD3 AMD 970A (Socket AM3+) DDR3 Motherboard
£86.99
Microsoft Windows 7 Home Premium SP1 64-Bit - OEM (GFC-02050)
£83.99
Corsair 2013 Edition Gamer Series GS 600W '80 Plus Bronze' Power Supply (CP-9020063-UK)
£65.99
TeamGroup Vulcan RED 8GB (2x4GB) DDR3 PC3-17100C11 2133MHz Dual Channel Kit (TLD38G2133HC11ADC01)
£64.00
Toshiba SSD HG5D Series THNSNH 7mm 60GB Solid State Hard Drive - (THNSNH060GCST)
£61.99
Seagate Barracuda 7200RPM 1TB SATA 6Gb/s 64MB Cache - OEM (ST1000DM003) HDD
£53.99
Prolimatech Megahalems Rev C CPU Cooler (Socket 775 / 1150 / 1155 / 1156 / 1366 / 2011 / AM2 / AM2+ / AM3 / FM1 / FM2)
£42.98
Asus Xonar DG 5.1 PCI Sound Card with built in Headphone Amp - OEM
£20.99
OcUK 20x DVD±RW SATA ReWriter (Black) - OEM
£11.99
Total : £801.48 (£844.86 in configurator)
I'm guessing the price is different because I left out a fan and a case xD
Is this build okay? Would an Intel build be better? And could I get the level of gaming I want for cheaper?
Please bear in mind that my options are limited by the configurator :s
Alternatively, are there any premade systems that I should consider?
I apologize that this is so long, I will be surprised and also very grateful if someone replies!
Also sorry my basket/build list is a mess, I couldn't work out how everyone manages to copy theirs all neat and tidy :/
Your basket
£95.99
£86.99
£83.99
£65.99
£64.00
£61.99
£53.99
£42.98
£20.99
£11.99
