build me a system
22 Feb 2013
Near Worcester
ok im building a system but need help with components. im going to overclock it.
I already have a
zalman z9 plus tower
Z77X-UD3H
I need everything else for the system except a mouse keyboard, ssd hard drive and os.
I have around 500 pounds for these items.
many thanks
matt
You are in a bit of a pickle fella as the UD3H mobo does SLI/Xfire so it does make sense to get a PSU that can run a 2nd GPU of your choosing. If you know you won't dual card then a good 500W PSU is ample for a single GPU setup
YOUR BASKET
1 x Intel Core i5-3570K 3.40GHz (Ivybridge) Socket LGA1155 Processor (77W) - Retail £189.95
1 x MSI HD 7850 OC 2048MB GDDR5 PCI-Express Graphics Cards with Tomb Raider & Bioshock PC Games £149.99
1 x BeQuiet Pure Power L8 630W '80 Plus Bronze' Modular Power Supply - With 120mm Silent Wing Fan Built in £74.99
1 x GeIL EVO Leggera 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (GEL38GB1600C9DC) £35.99
1 x Cooler Master Hyper 612S CPU Cooler (Socket 775 / 1155 / 1156 / 1366 / 2011 / AM2 / AM2+ / AM3 / FM1 / FM2) £32.99
1 x OcUK 24x DVD±RW SATA ReWriter (Black) - OEM £16.99
Total : £512.89 (includes shipping : £10.00).
I own the Z9 case too and I'll tell you now you really want to be looking at modular PSUs, there isn't much space between the back of the mobo tray and the side panel to hide cables. The Max length for GPUs is 290mm (off the top of my head), so be careful as some of the 7950 GPUs for example might not fit (the GB windforce does fit ok)
with a 7850 or 7950 not really any need to run dual GPU's though
Then why didn't he just buy the Z77-D3H? Just giving the guy the facts ;)
Not too keen on your basket if I'm honest. I'd take the MSI 7950 at the same price, it's clocked faster and has a 3 year warranty (HIS is 2 years). The Patriot RAM isn't low profile so fitting heatsinks over it could well be an issue. He wants to overclock so you need to add a cooler and no-one else has used a modular PSU either :(
ok I got a system all brought now
got an
i5 3570k
Z77X-UD3H
Kingston HyperX Beast 8GB (2x4GB) PC3-12800C9 1600MHz Dual Channel Kit (KHX16C9T3K2/8X)
Intel Liquid Cooling Solution CPU Cooler (Socket LGA1155 / 1156 / 1366 / 2011
cheers for all your help guys much appreciated
Thought you weren't looking for a water cooler?
Personally I would have spent a little extra and got the Kuhler 920 Series 4 if I was going to spend £75 ish on a CPU cooler.
You didn't mention what GPU you went for? :)
There was a Z77X-UD3H for £80 in B grade, which is the one he bought ;)
He seems to like rushing :rolleyes:
http://forums.overclockers.co.uk/showthread.php?p=23813379#post23813379
