Im contemplating upgrading my current PC. The thought that seems to be the most difficult to resolve is, should I buy a pre built system like a "Ultima Extreme SLi 8800 GTX", or should I buy the bits and build it myself.
I appreciate that I might save a few quid but I have done a number of builds in the past but I just dont know if I can be bothered with it any more, may just be better to get a pre built system.
"Ultima Extreme SLi 8800 GTX" is a serious indulgance I know, but may be buying the best system you can will (I presume) with full OCUK, back up & support be a good option.
This is not a "Oh why spend that much on a PC" thread, Im just gauging opinions.
Thanks in advance
Thanks in advance
