- 11 Jun 2021
- Glasgow
If you could buy a 3070 PC already built or buy the parts (and save £100-200). The already build has only ASUS TUF pieces and it takes up to 30 days to arrive. The separate pieces are a mix of brand and is an EVGA GeForce RTX 3070 but I would get it at the end of the week. I build my current PC with my ex's help but aren't very experienced at it. My current partner can do it but he's worried about messing up and breaking everything since I'm spending a lot of money.
Built £1899: COMPONENT DESCRIPTION
Chassis ASUS TUF GT501
Motherboard ASUS TUF GAMING B560-PLUS WIFI
Processor Intel Core i7 11700K, 8C/16T, 3.6GHz – 5.0GHz
CPU Cooler ASUS TUF Gaming LC 240 RGB
Memory 16GB (2x8GB) Corsair Vengeance RGB PRO 3000MHz DDR4
Graphics Card 8GB ASUS GeForce RTX 3070 TUF GAMING OC
Power Supply 750W ASUS TUF GAMING - 80PLUS
System Drive 1TB WD Blue SN550 M.2 PCIe NVMe SSD
Self build bundle £1589:
Intel Core i7-11700K 11th Gen Rocket Lake 8 Core Processor
Gigabyte Z590 AORUS ELITE AX Socket LGA1200 ATX Motherboard
Corsair VENGEANCE RGB PRO 16GB (2 x 8GB) 3600MHz C18 DDR4 AMD Ryzen Tuned Memory Kit - Black
EVGA SuperNOVA 750 G5 - 750W 80 PLUS Gold Fully Modular PSU
EVGA GeForce RTX 3070 XC3 ULTRA GAMING Graphics Card
Windows 10 Home Edition 64Bit - OEM
Plan to get:
MSI MAG CORELIQUID 240R CPU AIO Cooler '240mm Radiator £89.99
I already have a Corsair SPEC-DELTA Carbide Series, Case but I might get a new one with
CiT Flash ARGB PC Gaming Case £39.40
Plan to get:
