build problem.
12 Nov 2007
hi guys, just recently bought an Akasa AK-ZEN-01-BK Zen case, thinking it was an ATX, but it says ATX midi on the box. will this still be compatible with Abit IP35-E (Socket 775) PCI-Express DDR2 Motherboard, and 8800 GT graphics? also the Corsair VX 450W ATX PSU i recieved says its compatible with ATX 2.0. i posted the rig on here and a few guys said it will all be fine. should i send back the case or start building?
cheers
just start building as everything should fit fine, send it back if you decide you dont like the look of it
If it said mini then that's when you should be worried. Midi can take full ATX & microATX mobos.
Also, midi & most mini cases can take standard size ATX PSUs (2.0 is to do with features & not dimesnions) :)
Maybe this might be useful ;)
