- 3 Jan 2009
- Derbyshire, UK
Hi All,
Sorry for this being my first post
. Hope you dont mind me going straight into a potential build.
Anyway, I've been an AMD fan for a long time, but I think my old rig is starting to get a little outdated and I've been offered a pretty good price for it, so I'm looking at building a new rig.
Current spec:
AMD X2 3800+ OC'd @ 2.2 (Not a lot, but not mine for much longer)
MSI K9F Neo-F Mobo
4Gb Patriot Viper 800
Saphire X1650XT OC'd @ 621Mhz GPU - 770Mhz GMS
HDD - I cant remember, but an Average WD unit
Arctic Cooling Freezer CPU Cooler
Generic PSU and Xblade Case
It's a reasonable rig, and the X1650XT is so under rated, out performs several 9800GT's, some good freinds run, which I was pleasently suprised at.
However, that's now and I'm looking at updating a lot and keeping it future proof for a good while, or at least not require major upgrades for the forseable future.
Here's my Proposed Build:
MOBO - Asus Rampage Extreme or Asus P5E Deluxe (Either DDR2 or 3 model of either board) --- RE @ £200-£220, P5E @ £170-£210
CPU - Intel Q6600 G0 --- @ £150
HDD - WD 640Gb (WD6400AAKS) --- @ £44 (The Twin 320Gb Platter)
RAM - Unsure, kinda depends on DDR2/3 choice, but advice welcome --- @ <£100
GFX - Palit 4870 Duel R or 2x 4850 in Crossfire (Which is better?) --- 70@ £180, 50's @ £240 Total
CASE - CoolerMaster CM690 --- @ £60
COOLING - Watercooling? Need advice ...
PSU - Jeantech 700W Modular or Hiper 780W Type-M non-Modular --- Jean @ £70, Hiper @ £80 (Advice gratefully received if better options)
I've read so many reveiws, tried to catch up what's going on (2.5 years out of the computer scene), I think this should be a pretty fast system.
The Q6600 I'd aim to get about 3.6/3.8Mhz stable to run on water.
The GFX probably wouldn't be tweaked to much, but will push for as high a setting I can get stable. And knowing the Palit, probably maed out in Overdrive, even in "Turbo" mode, which is one of it's pre-set settings, changeable by switch on the back.
This will be my everyday system (Only system), used for Gaming, 3D Modelling, 2D CAD, Photoshop, Offline php/sql/html server for development of sites, basically everything, but above are main uses as far as I can think of, most likely more I have forgotten.
I will happily take advaice on anything.
I hope I've provided a good amount of info for your help and I really appreciate it. I also hope this is in the right place, I hunted about but couldn't find a more suitable place.
Thanks in advance,
Luke.
P.S. I'm also looking for value, the above is pushing it tbh. Screen it will run is a 22" Widescreen.
On a side not, I assume the X48 chipset is still top dog for clocking?
Would the P45 be better, even if it did mean running one GFX card (can only then run xFire at 8x/8x, which is a bit pointless with 16x/16x available)
Current spec:
MSI K9F Neo-F Mobo
Thanks in advance,
Luke.
