Build review
14 Apr 2009
Cheshire
OK settling on a new build.
I'm coming from whats in my sig. Will harvest 1080ti and I have a a spare quality psu.
Thoughts on below...
My basket at Overclockers UK:
Total: £608.92 (includes shipping: £0.00)​
@inoton - do you intend clocking/tweaking the memory?
If not, i would consider bumping down to a cheaper 3200MHz kit (like above) and use the cash saved to get a 1TB standard SSD (Crucial MX 500) ~£100 - same real world speed (if primary use gaming) and can be hidden away in your case with some tape/velcro.
*Unless you want to play with the form factor?..
Probably not actually. It is more asthetics....i like the look of the dark pro RAM.
Will consider though.
Edit... Actually that lpx looks alright.
Hmm. Defo want an m. 2 as it's something new for me. I appreciate its plug in and use, but still that is part of the excitement. Although I might get an SSD too, and I'll shortlist the m500 as position 1.
Any other low profile clean and simple ram sticks around?
The TeamGroup Vulcan when plugged in look pretty tidy - you only see the tops of the memory:
Total: £89.99 (includes shipping: £0.00)
Ignore the red imagine in grey - but you'll get the idea of what they look like in situ - fast forward to 4:30:
