Build spec.
14 Sep 2009
Northumberland
I know you will shoot me down, but the GPU is a replacement for another PC.
A GTX 275 goes in this :)
I'm sure this will all work together, but is the PSU strong enough, and have enough connections?
Youll want a better gfx card than that in there, lol ;)
looks good and yeah the psu will be fine for a single card set up, if you have plans to add a 2nd 275 in future it might be worth getting a stronger psu now though, 650 should still cover it
I have a 360 too, so the GTX275 will be a Billy-no-SLi's :p
edit: The case is like your sig :)
SEXAYY! :p
3450 DIEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEE
TBH the psu is overkill a bit for that, u could get away with a 400 but that psus fine.
