- 15 Nov 2011
I`m trying to put together final specs for my x79 build. The cpu (3930K) is on it`s way via RoyalMail, and everything else is pretty much waiting to be ordered/decided..
What i have so far and need help finalising are as follows:
Ram (32Gb): GSkillRipjawZ 1866Mhz 8x4Gb or a couple of Corsair 16Gb packs.
Mobo: Completely undecided which brand/product to go for.
Cooler: CorsairH100 though undecided about that.
PSU: Also undecided on specific unit - prob 650Watt Corsair.
GPU: GTX 570 i think.
Case: Corsair one probably, not interested in uber-gamer looks.
SSD: Random 120Gb one.
As i say pretty much undecided on specifics for a few things. The mobo / cooling and PSU i`d really like some advice on, don`t want to make the wrong choices there and regret it afterwards!
The system will be used primarily for multimedia ( ie 3d modelling / rendering / photoshop / after-effects etc ) and some BF3 action on the side. Hoping to overclock the 3930K to maybe 4.6/4.7Ghz ( don`t want to go nuts as long renders will push the temps a LOT ).
