ok big build started, reading all carefully lol
first question I come across, may be obvious but want this to go smoothly
1. seasonic 600 watt into a PC7, I presume fan points into the case? trouble getting bracket holes to match...hmmm....don't seem to..
sorry for the noob questions
LOL plate fitted by missus in five seconds why I been staring at it for 20 minutes
If your talking about what I think you are then as semi-pro waster said, the big fan on the PSU should be pointing into the case. By plate, I'm guessing you mean the I/O plate? If so, it should just snap in and you can see which way around it goes because there are little drawings of keyboards and mice etc- these should be visible from outside the case
